Just Purchased 2002 - Maintenance?
Boro4Runner
Just purchased a 2002 with 200,800 miles. Had all the maintenance records with the vehicle and it looks like routine oil changes but nothing else. See on the engine the timing belt was replaced at 100,000 miles. Taking it in this week to have the following:
coolant change
transmission fluid change
timing belt replaced
water pump replaced
Any other suggestions?
I suggest:
Differential fluid change
Brake Fluid change (if it looks dark, normally they're clear)
Power Steering fluid change (if it looks dark, normally they're clear)
Air Filter change
Fuel Filter change
Spark plug change (since you're replacing your timing belt)
