Just Purchased my first Runner! Q's?
206pete
Hello,
Just picked up my first gen '89 Runner DLX V6.
Anything I should do instantly to it?
116k original miles. completely stock.
Thought about getting the flamethrower fuel injectors, anything else you guys recommend?
Thanks.
Change all the fluids, do a complete tune job under the hood, get all your recommended maintenance baselined. Worry about mods later.
1. Change all fluids (engine oil, tranny, differential, transfer case fluids, coolant).
2. Check all other fluids (power steering fluid, brake fluid)
3. Adjust valves and install a new valve cover gasket
4. Lube all grease fittings (drive train/U-joints, ball joints, tie-rods)
5. check air filter, new one if needed
6. check front end for excessive play - does it need new bearings and/or ball joints? Failed bearings or ball joints can be very dangerous and expensive.
Have fun : )
Mike
seltzernator
