K&N Air Filter Now Available for V6!!
JGRIMBALL
TO: JUSTIN GRIMBALL,
Thank you for your interest in K&N. You have registered to receive notification about products for your vehicle. This email was sent automatically to inform you of available products that fit this application. Listed below are the current K&N products for a 2003 TOYOTA 4 RUNNER 4.0L. We believe this is equivalent to your request for a 2003 TOYOTA 4RUNNER 4.0L.
Year Engine Product Type Part Number Description Comment
2003 4.0L V6 F/I Air Filter 33-2281 NEW! Replacement Air Filter All
More information about our complete line of products is available at www.knfilters.com. Please contact us if you have any additional questions.
Thank you for choosing K&N!
Yes, you must order by part number... their online catalog hasn't been updated as the filter was just released on Oct 13th.
Bryan,
Thanks for the order. Yes, this is the correct filter part number for your 4 Runner. I would expect your filter to ship either Friday or Monday from California. It will come directly from K&N in California as we are waiting for our shipment to arrive.
Frank
Martel Brothers Performance
"World's Largest Automotive Catalog Website"
www.martelbrothers.com
800-882-7223
ordered mine last night no idea when ill get it though. i ordered it from martel. My exhuast will be arriving in cali on nov 8-13 which means i get it 5 days later
I also just order fomr martel and they said it would ship 10/23.
Hopefully this is true. I dont know why it is so hard to get a damn filter that just came out.
Auto Zone: We cant order it.
Advanced Auto Parts: We cant order it.
Napa: We cant order it.
4filters.com: Back ordered?
Perforamce products: 2 months?
Martel: :dunno:
K&N Filter Received/Installed on 10/23
Martel Bros delivered as promised... My filter was shipped directly from K&N and arrived yesterday afternoon. You'll notice that the K&N is about 1/3 "thinner" than the stock OEM Toyota filter, likely to increase airflow, while still adequately filtering incoming airflow. Since the stock tube is pulling cold air from outside the engine compartment, I doubt an intake kit would gain much over this drop in filter. Comments on this?
I disconnected the negative battery terminal before I installed it, so the ECU would be reset. You can hear a slight difference in the intake, more so on hard accelleration. It'll take a bit to see if I notice any noticible performance gains.. but hey, if my fuel economy goes up one or two mpg, and I don't have to clean this thing for 30K mi or so, it was worth the $40.
The black cable on the battery (also marked -) is the negative terminal (you'll also see a cable attached to it that runs to the body) I disconnected before I started -- I'm guessing good rule of thumb is leave it disconnected at least 15 minutes.
Yes, you'll lose your radio presets... and you'll also have to reset your driver side "auto down" window. You'll notice the backlighing in the button flashing when power is restored. Just lower the window halfway then raise it back up and hold the power window button in the up position for a few seconds and release. The autodown function should resume. (per the owners manual)
What does resetting the ecu do?
i think when i got my dual exhaust they didnt reset it.
Also Why does the negitvie reset not postive?
Dumb questions but i just want to know.
you could pull either cable and that would reset the computer but the rule is to take off the ground first to avoid sparks.
Resetting the ecu gives it a chance to relearn what it has like air flow. I don't know if it really works for just an air filter because its not that big of a change to the system not like changing a cam or heads.
