• TAP is reportedly Out of Business Oct. 2022 per this thread.
KC 5-watt Cyclone LED Accessory Light Kits
KC’s new 5-watt Cyclone LED accessory lights are the perfect solution to easily provide extra lighting wherever you desire or need it most.
The Cyclone’s compact 2.2″ diameter and flat .53″ thick profile allows it to be mounted virtually anywhere. Use it as an under hood engine bay light, dome light, rock light, emergency repair light, accent light and much more – your imagination is the only limit for its uses.
This 5-Watt, 12-LED light is rated at 1100 Lumens output. It’s IP68 rated dust and waterproof design makes it great for off-road motorsports, rock crawling and other applications where exposure to the elements may be a concern.
Cyclone LED accessory lights come ready to wire into any 6 to 16 volt power source. Mounting is simple as they attach anywhere with a Dzus clip or other readily available fasteners.
KC Cyclones are available individually in a choice of clear, diffused, amber, red, blue or green models.
Also available are ready-to-install, single-light kits that include wiring and waterproof switch for Universal and Jeep JK under hood applications. A two-light Ford Raptor under hood kit is also available from Total Automotive Performance.
KC 5-watt Cyclone LED Accessory Lights:
KC 5-watt Cyclone LED Light Kits:
youngrk
