KC, Hella, Piaa, Whata?
jhuerta22
Member
So after surviving my first deer accident with my rig relatively intact (fist sized dent in my bumper) I'm looking at getting some auxiliary driving lamps installed to help me see them before they total my truck. I was thinking if installing some ditch lights, and I'd like to stick with a halogen setup. My question is what brand do most people like to run here? I'm open to suggestions as I'm still new to this kind of stuff.
I have some IPF 968s that are the "combo" pattern. I really like them, but being Halogen they're nowhere NEAR as bright as my headlights.
If I were you, I'd fix the issue (crappy OEM headlights) before adding a bandaid to it.
The "new" morimoto mini d2s retrofits are so easy to install that I have a tough time calling them a retrofit. And the price... It's right.
If you're dead set on adding some halogen ditch lights I don't think you can go wrong with any of the bigger (more expensive) brands.
Im running Hella 500's (driving pattern) with PIAA Xtreme white xenon bulbs, and they shoot hella far and are hella bright lol. They basically are long throw spots so they are nice on an open night hiway. but the stock bulbs kinda sucked, so I recommend swapping them out to PIAA's
If you want to run ditch lights I would recommend some Rigid Duallys. I know they are not halogen, but I use mine almost every night because of work. They are so bright and they have a very good light pattern!
The "new" morimoto mini d2s retrofits are so easy to install that I have a tough time calling them a retrofit. And the price... It's right. s.
On my bank account isn't going to like me tomorrow. This is the first time I've seen these, and have put off doing the retrofit due to the time required/complexity of it. This makes it crazy easy. Been saving for new tires....but oh well. As to the OP, I just installed a pair of rigid driving d2 on my bumper as well as a pair of rigid d2 in the hyperspots on cbi ditch light brackets. All I can say is that the hyperspots are ridiculously bright.
If you're going to use them on pavement, you want DOT certified driving lamps and there's probably limitations on where you can mount them. I don't think they can be higher than your headlights.
I assumed these were lights you were only going to run when others aren't around correct? If so check out the MRT lights I did a review on a few weeks ago. They sound like exactly what you need. I don't think I can out drive those lights they shoot so far...
Why run aux driving lights when you still have factory POS halogen headlights? Order and install these. Be sure to use 55 watt ballasts. The difference is staggering. If you still need more light, which you won't for on-road driving, then get some Hella 500's and do a HID retrofit with 55 watt ballasts. Mount them to some CBI Ditch Brackets.
Pardon my noobness, but I would like the white xenon. That's what I have in my headlights at the moment any they project a lot better than my OEM halogens. The issue wasn't not being able to see the deer ahead of me, but where it was off the road before it decided to run in front of me. As difficult as this is to wrap your head around, I'm not big on the LED's. They'd look out of place to me. Maybe if I had a 4th or 5th Gen I'd think about it.
The idea behind the additional driving lights is to have similar beam distance as the main headlights, but have the width to spot them out beyond the road. Maybe I should run spotlights rather than driving lights? These are mainly for use around where I live as only 30% of the roads are paved and we have herds of deer in the hundreds.
As far as state statutes go, I can always talk to my boss and see if he thinks it's something he'd have an issue with. This is right from the statute book itself:
60-6,225. Spotlights; auxiliary driving lights; signal lights; other devices; intensity and direction.
(1) Any motor vehicle may be equipped with spotlights as specified in section 60-6,219, and every lighted spotlight shall be so aimed and used upon approaching another vehicle that no part of the beam will be directed to the left of the center of the highway nor more than one hundred feet ahead of the vehicle.
(2) Any motor vehicle may be equipped with not to exceed two auxiliary driving lights mounted on the front at a height not less than twelve inches nor more than forty-two inches above the level surface on which the vehicle stands, and every such auxiliary driving light shall meet the requirements and limitations set forth in section 60-6,221. The restrictions on mounting height provided in this subsection shall not apply to any motor vehicle equipped with a blade, plow, or any other device designed for the movement of snow. Auxiliary driving lights shall be turned off at the same time the motor vehicle's headlights are required to be dimmed when approaching another vehicle from either the front or the rear.
(3) Whenever a motor vehicle is equipped with a signal light, the signal light shall be so constructed and located on the vehicle as to give a signal which shall be plainly visible in normal sunlight from a distance of one hundred feet to the rear of the vehicle but shall not project a glaring or dazzling light.
(4) Any device, other than headlights, spotlights, or auxiliary driving lights, which projects a beam of light of an intensity greater than twenty-five candlepower shall be so directed that no part of the beam will strike the level of the surface on which the vehicle stands at a distance of more than fifty feet from the vehicle.
Sounds like I would have to run spots to be able to check ditches, but most of the time they'd be used when I'm off highway and knowing how it goes around here the only people who may have an issue with them is possibly State Patrol. We don't bother with that stuff too much, as about every rancher and his dog has a go light on the roof of their rig for 'checking cattle'.
What is the PIAA bulb part number?
Hey Absalom what do you use for the rest of the options with that retrofit? Also how much of a PIA is it to change a bulb on that once you have done the retrofit?
what am I missing, they don't show em available for toyota's??
They fit the Hella 500 lights that people add on to the 4runner. They don't fit the headlights
If you want PIAA Bulbs for your 4runners headlights you need H4's which are these bulbs: PIAA | H4 XTreme White Plus Twin Pack Halogen Bulbs #15224
I personally run them along with the H3's in my 4runner and they are a HUGE improvement in light output.
the H3's that fit the hellas are these: PIAA | H3 XTreme White Plus Twin Pack Halogen Bulbs #15223
Is that for the mod for factory headlights, or replacements for the fog lights? My xenons do well for projecting ahead, I need more beam width, so I figured some auxiliary lights could give me a little more towards the ditches.
I bought these side mirror brackets from Yodateq. They're made for FJ 80's, but I figured I can make them work. I took measurements and the won't fit as is, so I'm either going to modify these or use them as a template for building my own and sell these.
delislerebecca
