I'm also looking at a spacer kit (I don't want to spend all the money on a complete suspension do-over) for a 2014 4WD Limited and I'm being asked if I have the electronic leveler/pneumatic suspension leveler thingamajobby. Apparently some have it, some don't.
How the hell do I figure that out? Is there something in/on the vehicle I can use to easily identify that, am I going to need to crawl under it and manually inspect, or will I have to call the original dealer with the VIN?
Thanks in advance for any help!!
A body lift is not the way to go. You may run into wiring and cable (parking and trans) issues. Plus you're putting extra leversge on the body mounts. A buddy ripped a mount from the body on his Ranger.
All Limited have XRES.
Thanks! I really appreciate the help. So can I do the spacer kit or should I just spend the extra $1,500 and get some kind of suspension lift/upgrade?
Body lift should not affect KDSS. The biggest concern I would have is doing a 2-3 inch body lift. I have heard of a few attempts at a 2" BL with alot of issues and I have not heard of any 3" BL's on the 5th gen. I am running a 3" suspension lift + 1" BL lift w/ KDSS and no issues.
This is EXACTLY what I wanted to do. 1” body lift.. any problems ? Anything to look out for? You did 1” all around? What spacers. ?
Spacer lifts go on the suspension which is different than a body lift. I have had no issues with doing a 1" body lift.
I know ZERO, about body lifts, is this something you buy for all 4 corners? What’s a decent brand? Or can you just get anything off Amazon?
