LOL, it sure sounds like it at times haha.
KDSS isn't available in the "Gulf states". That means from Texas to Florida. I think you can special order it. I would guess the same would be true in northern New England. Not sure what the thought is on that unless it has to do with trying to sell more GX460's where KDSS is a standard feature and comes in all of them. It's really pretty silly if you ask me, down here in the south you may not be 4x4 all the time but we drive on the highway alot and KDSS makes a big difference around corners.
I bought mine in Peoria, AZ and drove it home.
Not sure where you got your info, but KDSS is most certainly available on the lot the the Gulf States. I live in FL, and see them at the dealership lot all the time. Matter of fact, most of the Trail editions come with the slider installed too.
I don't understand why the pro doesn't have KDSS or a sunroof (as that seems to be a big complaint)
Yes, for the same reason why they don't offer the Pro with KDSS: it's made in Japan. Bear with me.
It's made in Japan at the Tahara plant, which is one of the most automated factories in the world. The 4Runner is likely its most mature assembly line there, since the truck has been around since 2009. It's also the one with the smallest throughput (units sold). Changes in integration (yes, including adding more paint colors) disrupt the 4Runner's tightly run assembly and takt times, on an export-only vehicle that is already at the mercy of import tariffs. Just adding paint colors is probably enough to shave profit margin down to unbearable levels. The Pro is the exception, and they charge dearly for the new changes (up again by $3500 this year). By contrast, pickup production is in San Antonio with 2 shifts and in the case of the Tacoma, more demand than supply. They have no tariffs and by extension, a more comfortable profit margin.
For the same reason, they do not install Pro suspension or any other trim pieces on the 4Runner in Japan- it would disrupt a mature and optimized production process. All Pro trucks (4R, Tundra, Tacoma) start with the Off Road model and then are changed by a TRD task team AFTER the assembly is complete. In the 4Runner's case, after it arrives port-side in the US. This is justifiable for a small volume of units that command a vastly higher price, such as the Pro.
When Toyota reviewed the man-hours required for the Pro upgrade task team, they still have to make sure there is a comfortable margin. It is my assertion that the complete disassembly of the KDSS end links and extra cylinder manipulation would kill this margin. Thus, no KDSS availability on the Pro.
Then they are not getting their 4runners using the regular Gulf method. KDSS is special order only for those states. I searched for months and found this the hard way until I found a dealership in Texas that traded with a non-gulf dealership.
From my other post:
ugly roof rack
I'd say the work done at the port is part of an import agreement rather than disrupting the assembly line.
I have no idea what you mean by that. What import agreement, and why would portside installs affect it?
Correct. This process of port installed items started some years ago when it was determined that many items "went missing" in transit. Accordingly, manufacturers started shipping some easily pilferable items in a containers like mats and tools. That then expanded to radios and other parts that required installation and now also includes locally sourced items.All i'm saying is with the tariffs and trade deals who knows exactly why they do stuff like install things at the ports (AMPORTS ) instead of at the factory, but as in the past with installing truck beds after the vehicles arrived in the US, AC as a dealer installed upgrade, NUMMI manufactured vehicles, or even moving assembly plants to the US, everything they do in this regard does have a reason and imo it's not because of the existing assembly line and not wanting to change it. I'm sure it's been changed / updated, at least I hope it has been to some degree or another over the last decade.
I'm just talking changing or adding paint colors. It's a simple change that isn't going to hose up Toyota's carefully cultivated process.
As you've said, this is basically Toyota's most mature vehicle. Swapping out a paint color isn't going to wreck their profits on it.
