keep dropping cylinders?
4ballin
I recently started having a miss fire problem when it was real moist outside.I had a friend put it up on one of those snap on diagnostics scanner thing and it told him that i had a misfire in cyl #1.I thought it was the ign coils and wires so i replaced all 3 and wires and guess what its still doing same thing.It seems to do it after i have left it idle for awhile and then get in and drive it does it.It being it has no power and it sounds like a pos mid 90s caddy that no can afford to put ignition coils on so its runnung on about half cylinders.It sputters and has no power.I also tried spraying starting fluid around intake to see if idle smoothed out but no luck.Like i said it seemed to do it when it was moist out and then would clear up after a little driving but now its getting worse progressively.Check light comes on and flashes for e few and then stays on and then sometimes goes out while engine is still acting up.Does anyone have any suggestions that can save a brotha some money since i just spent $250 on all coils and wires and it didnt help?Thanks a lot boys!
