Keeping a Deflated Spare?
0xfded
O wiser ones,
I have a question about keeping a spare in an aired down state, maybe with a strap squeezing it so that it fits in place.
Context: I just added a 4xInnovation rear bumper. Unfortunately, my 265/70/R17's are about an inch too wide to store in the stock location--it contacts the panhard bar, and the hitch on the bumper. (Note: this is 100% my fault. 4xI has been great, and informed me in advance what size tire would fit, but I dumbly measured the width of the tire while it was on the vehicle. Stupid.)
I have a serviceable onboard compressor, so I played around with airing down the spare and then using a ratchet strap to snug it in about an inch. But I don't know if this is going to unseat or outright ruin the tire over time.
Is this just a dumb idea?
I know it doesn't hurt the tire to keep it deflated, but applying a constant localized pressure via a strap over long time periods could deform the tire.
Which also happens to the spare since it sits against frame rails. Even when inflated.
The strap was a little more alarming when I tried it out, because it was a really localized deformation. More of a pinch, rather than broad compression.
You guys have me thinking I should try airing it all the way down to nothing and seeing if that allows it to tuck in. I half suspect that doing that may let it fit in, but then the lack of pressure means it won't be snug against the rails.
I suspect a tire carrier might be in the cards later this year.
This should go without saying, but needs to be mentioned. There is risk in this idea even if there isn't damage to the spare. I take my rig in remote enough areas that I want to make sure I have an inflated, usable spare in spite of carrying a high end, robust air compresser. It would suck to have a flat tire, flat spare and a compresser that just went belly up out on the trail somewhere.
They have $50 compressors that are beast mode, very reliable and will fill a 33" tire in about 5 minutes. I would trust that compressor no problem. If not I would be in situations with 10psi aired tires leaving the trail many times.
ViAir 88p is a good, affordable compressor (I'm sure you can spend more and get a better portable). 16 to 35psi in about 4-5 minutes. I run it for about 20 minutes at a time and no issues at all with it.
Yeah my brother has that one. We have done 8 tires in a row, hot weather for about 40 minutes and it never shut off.
I have the superflow mv50, Masterflow 12v High Volume Air Compressor / Inflator - Walmart.com.
Both pumps work about the same and are affordable.
Yep, totally hear this. But at the moment, it might be a choice between a deflated spare and compressor, or no spare. That's the main reason I think my long term choice is adding a tire carrier, or switching bumpers.
But I do keep a ViAir 85P in my trouble kit, and have used it a couple of times to make sure it isn't a dud (most recently to re-inflate the spare in question).
Something to experiment with this weekend. Thanks for your thoughts guys, it seems like I'm not completely out of my mind on this one.
toyodajunkie
