Kenda Klever M/T 265/70/17
tylka4runner
Anyone running the Kenda Klever M/T 265/70/17 tires? Are they super loud for an m/t and approx. How long do they last? I have a 1" leveling kit going up to 265/70 will fit with no issues?
I love Kenda mountain bike tires. But I have seen tires in person with lugs ripped off. Personally I would keep looking. But that is my 2 cents.
Great tire for your bike but stay away from their auto tires.. Buddy had a set on his ride and they were dead in less than 10000KM as stated above lugs ripped off and sidewall deformations..There are better cheap tires out there IMHO
The shop is mounting 255/75-17s onto my stock wheels right now. The tires look fantastic in person and the price is very competitive on them. From what I understand, Cooper bought out Kenda fully as of a few years ago. The quality, in theory, should be pretty good with these automotive tires.
I have seen a couple of pictures online of these Kenda MTs coming apart when new. However, how many people are using these without issue compared to those who've had problems? Probably a lot. I know there are very positive reviews online about these as well.
I'll post pics tonight and give a review of them after they are installed on the 4R which might be this weekend (I have two sets of wheels/tires currently).
Well, here are some specs for the 255/75-17 Kenda KR29 MT mounted on a factory aluminum wheel:
Tread width 8.25"
Section width 10.5"
Tread depth 18/32nds
Weight of wheel and tire 77 lbs
Height from ground to top of tire 31.5"
Average weight to balance 5 oz
These things are huge for their size. I'm wondering if they will even fit. I might have gone overboard. They are a full .5" taller than a 265/70. And compared to the stock tires they dwarf them!
Looks good. Please update us on the wear.
How much were they?
Mounting, balancing, tax, alignment, etc. out the door was $750. It's hard to even find an all-terrain tire for that kind of deal.
If you want, you can order them off ebay for $520 delivered to your door...but then you have to take care of mounting and balancing on your own.
Tonight I will install the fronts and see if they actually will fit. I'm concerned about that. If they don't fit I'll be taking them back for a different tire that isn't as big.
You shouldn't have any trouble fitting. I am running the same size and I ran them with a spacer lift originally. If you do wheel spacers you will need to trim and push the fender liners forward.
That's good to hear. I knew these would be taller than stock (which is what I wanted) but I didn't expect them to measure out a full 2" taller. Oops. :whistle: But as long as they fit with no rubbing I'll be happy. And my speedometer will finally stop reading too fast!
i love kenda mountain bike tires. But i have seen tires in person with lugs ripped off. Personally i would keep looking. But that is my 2 cents.
funny cause i dont linke kenda mtb tires to much the nevigal super tackeys i cant keep the lugs on them. All the side lugs get torn off. So they have issue with car tires and mtb tires keeping lugs on hahaha.
Haha.. I am running small block 8's right now. So far so good. I had a kenda nevegal tubeless version a few years ago rip some blocks off at the 24hrs of Moab. But no issues since then.
Two early observations.. They are louder than I expected. They are rough below 5 MPH like a lot of mud tires. After that pretty smooth. Above 45 they get loud.
Also, my MPGs on the display are dropping immediately. I always see that when I upsize tires but I just hope it doesn't fall too far.
I have read good reviews, got any pics on the truck? They also make an A/T, but I like the looks of the M/T's. I really need something to fill my gaps.
Hit the interstate this morning and at 70 they rolled smooth with zero shimmy in the steering wheel. They are noisy but they are NOT as loud as the BFG KM2 I ran before.
The front is VERY tight with the 1.75" lift. I can't believe some guys can run these on stock suspension. I have literally 1/16" between the mud flaps and tire and front fender lining and tire. It's ok on the street but off-road it's gonna rub like hell.
At 31 psi a chalk test shows them over inflated. The outer lugs aren't touching the road. 25 psi would be perfect for wear, bit I will stay around 30 psi to try and hold onto any fuel economy I can.
After 35 miles the TPMS light still hasn't tripped. I'm using regular valve stems in all 4 new tires and I expected this to make the light on the dash come on. So far it hasn't.
Pics coming later.
Pics coming later.
whats the latest ? had them offroad yet ? any issues with wear so far ? thanks !
The latest is I had zero issues with them. They were wearing great, looked perfect, and worked fantastic on the road. I ended up having one of them replaced under warranty because it was out of round. After that all of them rolled smooth at all speeds, not just interstate. They were pretty loud but not the loudest I've experienced with MTs. For the money you simply cannot beat them.
BUT...
The weight surprised me. They were LT "C" and I expected that they'd therefore be closer to 40-45 lbs. in weight. In reality, they tipped the scales at 50 lbs. and they were absolutely destroying my fuel economy. I was losing a solid 2 MPGs and that is about $30 bucks a month for me. I couldn't pull 15 MPGs on a tank. That meant that with winter coming I'd have been in the 13.5 to 14 MPG range on the winter fuel. That is unacceptable to me with fuel at $3.50/gallon. So the Kendas found a new home.
I'm now running Cooper AT3s and I freaking love them. Almost all my fuel economy has been restored, and I can still tackle any terrain that I usually find myself in. They are quiet and safe in foul weather. Will be much better for winter coming up here in KY.
If fuel economy is not a concern for you at all, and you know for a fact that you are going to buy a MT, I wouldn't hesitate to run the Kendas. Fantastic tire for the money.
Lets bring this thread back. Has anyone else besides WXman run these tires on their Runners?
I'm looking for some M/T to throw on come spring and these are actually one option i'm considering. I have a dedicated tire for the winter months so I'd only be running the M/T from about March till October/November.
I'm actually looking at the 285/70/17 in these Kenda Kelvers, at about $168 a piece, that's amazing ! I do have only a daystar 2.5/1.5 kit in with 1.5" Wheel spacers. I also have cut off a lot of the fender liner both front and behind the wheel and also cut off a bit of the front bumper . I think all I would need to fit in 285's would be to do the body mount chop which I will be doing before running them.
So ... back to original question. Do you guys think I should run the Kenda 285/70/17 M/T for about 6-7 months a year or a good hundred bucks more and get something different.
Thanks for the input . I'm still shopping around and contemplating on which size I want to go with.
Good luck with yours !
Keep an eye on the tread blocks. When I was getting my Nitto's mounted there was a guy a shop with multiple tread blocks separated from the casing. The guy working the counter claimed this wasn't the first person he has seen come in with this issue. They are no longer selling the Kendas. About a year ago we saw the same thing with a guy on the trail; Tread was separating..
Jhunt
