Key stuck will not go past acc problem solved.
knockerjoe
Update to a post I made recently: Found a bad shift positon switch, toyota part# 33805-35020. what happened was when the shifter goes to park it hits a plastic stop. This was out of adjustment and as a result damaged the shift position switch. To fix you must shim the stop and replace switch. I hope this helps someone in the future. Note this was on a 98 4runner v6 sr5.
Hello,
Just found your thread and it is exactly what we are experiencing with our 4runner. Too bad we didn't come across it before we replaced our ignition switch. Just curious, did you find any instructions online on how to replace the switch plate? We just ordered the part you listed (33805-35020).
Thanks so much for the helpful information!!
cycely
D'Angelo
