Kicker key 200.4 on 2021 stock HU ???
NeilYoung
Member
Looking to install the kicker amp on my entune 3.0 to improve the sound. I've already replaced the dash and front door speakers with infinity kappas. In the process, I have also sound deadened all 4 doors and the tailgate. I've read that the Beatsonic PA2T1 and the Kicker 200.4 are popular options. Just looking for some feedback from folks that have run the Kicker given the buit in DSP. Some plug n play install instructions and mounting location tips would also be appreciated.
Thanks in advance.
Mounting tip
I can't help you out too much as I own a 4th gen. I have sound dead in my entire truck though top to bottom, Sony touch screen in the front, all new wiring 3 amps, modified door frame to fit 3½ speakers + tweeters, subs,etc. The best advice I can give you when it comes to mounting something if you are able to in your runner is to get a 3/4-in piece of plywood and some big Velcro squares. Wherever you want to mount something pull the carpet up on the floor and stick the Velcro directly onto the metal body of the runner, The other piece of velcro stick to your 3/4-in plywood cut to whatever shape you need it to be and then stick it to the velcro on your truck underneath the carpet this will allow you to mount anything you want pretty much anywhere on the floor underneath your seats in the back etc without having to drill holes into the body of the truck and allow it to be removable and secured. You don't want to destroy anything just because it bounced around all over the place
I can't help you out too much as I own a 4th gen. I have sound dead in my entire truck though top to bottom, Sony touch screen in the front, all new wiring 3 amps, modified..... removable and secured. You don't want to destroy anything just because it bounced around all over the place
Good call. I like this.
I have thought about adding strips of deadening material to the doors after I did my cargo storage mod and pulled out all of the existing foam. Do you feel it is worth it?
I'm very sorry for the late response. Are you asking if you should put sound deadening on the doors 4Runner, as I am a little confused because in your original message it says that you put sound deadening on all your doors. I apologize but I'm a little lost what are you asking is worth sound deadening?
2001ATL
