Kings or Fox
I stand corrected.. Mind sharing photos if your set up in context to sway bar + coil overs?
Alright here are some pics that I just snapped.
This is the misalignment spacer that shifts the entire shock body backwards to provide extra clearance for the sway bar.
Sway bar bracket spacer. Moves the bracket mounting position down and forward.
Plenty of space between the coilover and the swaybar.
SPC upper control arm
I couldn't grab a good shot of the clearance between the sway bar and the radiator support bracket due to the skid plate. That said, with the included radiator support bracket spacers there's plenty of space between the two.
Anyway, I hope these pics help.
If you'd like to see any other angles or have any questions just let me know!
Edit: Bonus shot of how it sits now with the lift installed. Running stock size Cooper AT/3 Tires.
After months of research and reading 1000s of treads, decided on the Kings. I called Ben from Filthy and ordered thru him. 2.5"with reservoir and compression adjustment. 3-4 weeks for delivery. Lets hope for the best and thank you all for the pitch.
You get Kings for front and rear? You install them yet?
seltzernator
