91bulldog said:hey,
i'm thinking about replacing my stock air filter w. a KN CAI...i'm just not sure if i should do it or not? Is there a big difference?
Iowa4Runner said:Keep it stock! A big difference? Not in a million years. The only difference is the amount of dirt that gets past your filter. Toyota's engineers knew what they were doing when they designed the intake system. They're not idiots. They didn't throw away precious horsepower to save a few bucks on an air filter. Don't fall for the K&N hype - Don't be a sucker...
TRD04RUNNER said:hahahha LOL! I don't think any stock intake is better then an open intake. Stock intake has to much air restricting.(they suck your HP) why do you think it so quite?? (cooler non restricted air = more power)ever cars I own since 1990 has an k&N filter at the end of the CAI. and ever time I clean the filer ever 15 to20k miles I ran a clean white rag trough the intake piping and has never pick up any dirt in it!(knock on wood) went trough clean came out clean! the dirtier the k$N filter is the better it trap dirt! I usually oil it twice after I clean it 2 make sure.
Why did Toyota choose to "suck the HP" out of the 4Runner by designing a bad intake system as you'd have us believe?
chillwihll said:Um, so Toyota is supposed to maximize horsepower and performance on an SUV? Obviously they're going to choose ride quality/all around comfort over horsepower... I dont think Toyota developed the 4runner to squeeze every possible bit of power out of it for us. BACK TO THE TOPIC...I didn't know k&n made a cold air intake. I thought they just had that stupid FIPK short ram thing that sucks air from the engine compartment?
Iowa4Runner said:All ingenious "hahaha LOL!" comments aside, answer me this - Why did Toyota choose to "suck the HP" out of the 4Runner by designing a bad intake system as you'd have us believe?
By the way, K&N doesn't oil their filters twice before flow testing them. I wouldn't be surprised if over-oiling them actually makes them more restrictive than the OEM paper filters. Wouldn't that be funny. Ahh who am I kidding, as long as the intake noise is nice and loud you KNOW you're getting a MASSIVE axle-snapping boost in performance. Sweet dude!!!
Bumpin' Yota said:And no an open element filter that has been over oiled will NOT flow less than the OEM garbage.
Iowa4Runner said:And we should believe this because "Bumpin' Yota" says so?
1. How do you justify calling the OEM filter garbage?
2. How well does a K&N filter flow when it's soaked in oil?
Please, give us more than pure speculation... Provide independent test data, or at a bare minimum give us logical, rational explanations to support these claims.
Bumpin' Yota said:Actually you should be the one providing test data as you were the one ignorantly pontificating about them, and I'd place a wager you have never even seen a KN filter much less used one, otherwise you would not be making such stupid claims.
As far as which flow better, very simple. The KN has a larger pore size (can be confirmed with the naked eye) and uses the oil's surface tension to trap various particles. OEM filters use the pore's size to trap particles and fiber entanglement.
Assuming that over oiling occludes all the pores (which it cannot as the oil used does not have a high enough surface tension to do this) it would merely be pulled into the intake system the moment the engine was fired up. Remeber this is very thin oil we are talking about here, not grease. (Its consistancy is much much less than 5w...) Thus the ONLY problem generated by an over oiled filter is it screwing up your MAF's heating element.
Now if you use an oil based, open element filter and let it get dirty as hell, guess what - then it clogs, as it is filtering better and better. (Pore size decreases)
Next time actually use something and more importantly have a grasp of how it works before you ignorantly bash it. I am at 260,000 miles on a 3vze '90 4runner with stock HG and still getting 20mpg so I am doing something correctly....
Iowa4Runner said:Hitman is that you? Did you relocate to Florida?
Boaz said:LOL I was thinking the same thing!
You might do well to follow your own advise. I hate to use the phrase raging hypocrite, but it's seems painfully applicable here. Obviously it's you who need to get a grasp of how things work, you who are ignorant. Let me quote a little something from K&N's web site- "When servicing a K&N filter, take care not to over-oil the element. Besides impeding air flow..." Did you catch that? IMPEDING AIR FLOW! Care to astonish us with more lessons on surface tension? Or how about the oil that you claim has a consistency much much less than 5W? Any chance you're referring to the aerosol oil that has the carrier solvent?
If ignorantly bashing things is so offensive to you, then why did you say the OEM filter was "garbage". Again, you've offered nothing to support this. Where are these "stupid claims" I made? I said the K&N would not make a big performance difference. I backed it up with the notion that Toyota hires capable engineers that would not design a lemon air intake system. It stands to reason that there'd be little room (if any) for improvement. If someone wants to justify spending $$$ for performance gains, the burden of proof is on them.
And by the way, I've owned and used a K&N air filter before, you assumed incorrectly. Have a nice day.
kimboy said:FYI, the amsoil air filter oil is think like molasses![]()
