Knocking sound from rear wheel well
zach1288
So I parallel parked my 4Runner outside my house last night and everything sounded fine. This morning I pull out and I hear a rhythmic knocking sound coming from the rear wheel well. It sounded like a hammer knocking the wheel well and increased with speed. I pumped the brakes a couple times going about 20MPH and the noise went away. I continued to work this morning and never heard it again?
Did you recently have brake work done? I'd check your caliper bolts.
Is the jack loose in the rear compartment above the wheel well? It has been known to cause a knocking noise.
it may be the e brake if you left it on and drove with it it will eventually make a weird noise
I actually have a similar noise as well that I have been chasing for a while and im hoping maybe eventually one of these threads and maybe this one points us to the right thing.
I have checked everything obvious, zip tied anything suspect, did the wiggle test on anything after that and re torqued any bolt I can get to. without any luck or change.
Do you hear it over bumps at any speed? when accelerating hard from a stop? windows up or only windows down? can you decipher which side its coming from?
charlesz
