Knocking sounds 4Runner
Sounds a little loud to be from within the engine, maybe a bad pulley? I'm thinking maybe it wobbles some as it's forced to spin faster then slow down some
I don't think that's a valve tap, normally that's the culprit. I agree, it sounds like something is loose and clanking around rather than a rhythmic knock.
Try a stethoscope to isolate. I had a similar noise on my 5vz when i had to loosen some things to move the knock sensor harness and forgot to retorque the cam pulley. The noise was the set pin hammering back and forth
ghengiskhan
