LANGKA - Touch Up Paint Blob Remover
bryancos
Hey guys... wanted to share a neat little product I ran across called "langka" for removing paint blobs and doing a great job of removing excess touch up paint for an almost invisible repair.
I've not tried this exact stuff, but when doing some recent touchup for paint chips, I used a similar 3M solvent. What you basically do is fill the chip w/ a touch up paint blob and let it dry. Then put some of the solvent on a tshirt stretched tight over the edge of a credit card and then carefully and slowly "smooth out" the 'paint blobs' so that the paint is finally flush with the surface. then you can apply a little brush on clearcoat and rewax the repair site after several days. I made some touchups that are barely visible and hard to find.
I think I'm going to order a kit of this tho... seems easier to work with:
www.langka.com
And for those of you with older vehicles, check out: www.paintscratch.com for exact match touch up paint pens, custom made spray cans, etc.
Thanks Bryancos!
This product sounds interesting and may give it a try. I always heard of doing it the hard way...paint then wet sand then polish. That way always scared me! I will definately try this...Thanks for the Info!
