Lasfit T-Series LED Turn Signal Bulbs - CANBUS Ready/Error Free/Anti Hyper Flash
lasfit
official vendor
Are you looking for high-performance LED turn signal bulbs with no hyper flash, error code free, and required no additional load resistors? or want to try the white/amber switchback LED for the turn signal? This post is for you. This post will give you more details about Lasfit T-series LED bulbs and why you should go with the Lasfit bulbs. If you have any questions or want to get LED turn signal bulbs for your other vehicles, please leave a comment below, PM, or email us.
attachment.php
Toyota 4Runner Turn Signal Lights Bulb Size:
1. 2013-2022 Toyota 4Runner
● Front turn signal light bulb size: 7444/7443
● Rear turn signal light bulb size: 7440
2. 2006-2013 Toyota 4Runner
● Front turn signal light bulb size: 1156
3. 2003-2005 Toyota 4Runner
● Front turn signal light bulb size: 7440 OR 4157
NOTE: there are two bulbs sizes for front turn signal lights, 7440 and 4157. Please check your stock bulb size.
Why did Lasfit develop T-Series LED turn signal bulbs?
You may have heard that the CANBUS / load resistor is required when replacing the halogen turn signal bulbs with after-market LED bulbs. Installing low-quality LED bulbs for turn signals, you will get hyper flash or error code warnings on the dash. Many users also complained that LED turn signal bulbs are not bright. Thus, Lasfit developed the T-Series LED turn signal bulbs. The T-Series has higher lumen output, a built-in CANBUS resistor, and NO hyper-flash.
attachment.php
Specification
CANBUS ready, plug and play
Lasfit T-series LED bulbs are designed with a CANBUS system in mind. No extra load resistor or additional wiring harness is required. Plug and play for easy installation.
Higher lumen output.
The max wattage on the T-Series bulb is 24W, and the max output lumen is 2400LM. LED bulbs use less energy and are more efficient than halogen ones. Lasfit T-Series LED turn signal bulbs are much brighter than halogen turn signal bulbs.
Intelligent Temperature Control (ITC)
An excellent Intelligent Temperature Control system will protect bulbs against excessive current and overheating and ensure a longer lifespan.
Safety Protection
A built-in mini fuse protects the bulbs and your cars against the instantaneous high current for safer installation and use.
Worry-Free Warranty
● 45 days money-back guarantee
● 45 days free return policy
● 1-year hassle-free warranty
attachment.php
About Lasfit switchback LED turn signal bulbs
YouTube Video Review
Switchback LED turn signal bulbs are designed for dual-filament bulbs only, such as 7443, 3157, 4257, and 1157. Generally, they are used for front turn signal lights. The switchback LED bulbs are white(in low power mode) and amber(in high power mode). When you turn on the DRL or parking light, the white light will be on. The bright amber will be on when you turn on the signal or hazard lights.
Notice:
If the stock halogen bulbs on the vehicle are dual-filament, such as 1157, and work as turn signals only, with no function of daytime running lights/parking lights. Only the amber light will work on the switchback LED bulbs, and the white lights will not work.
attachment.php
I have your 7440/7443 LED bulbs in my 2021 T4R both front and rear. I will agree that they're significantly brighter than stock. What I will disagree with is your claim of "no hyperflash." If you leave a directional or the 4 way flashers on for over a minute or so, you're quickly into hyperflash mode. I'll probably put up with it until the weather gets better, then return them.
Hey, thank you for your feedback. If bulbs start to hyper flash after a minute, don't worry, we can exchange it for a new pair, or you can return it for a refund. Our T-series LED turn signal bulbs have a built-in temperature-control system, which keeps LED bulbs working well in a high-temperature environment within the given time, about 5-12 minutes(based on different headlight housing environments). The LED turn signal bulbs start hyper flash when they are too hot after running for about 5-12 minutes, which warns the driver to turn off the signal lights to rest. This function is to extend the lifespan of the LED signal bulbs. The bulbs will work again after cooling down for a minute or two.
Share two pictures from our customers [MENTION=476]Randy[/MENTION] Light. He installed T series 7443 switchback LED turn signal bulbs on his 4Runner, before and after comparison. Do you like the LED brightness?
Goodnight everybody.
attachment.php
attachment.php
Led Amber Turn Signals
"These Lights worked out Great for my 2019 Toyota Trd Off Road.I was out with a Large Group Off Roading The Sun just went down So we were running at about 50mph on a Dry Lake Bed and the Dirt was making a very large cloud All of the Rigs behind me said with those amber lights on We could All see you So they were Well worth the Price"
___ Thanks to [MENTION=145155]SMITH[/MENTION] Gene for sharing his experience with Lasfit T series LED turn signal bulbs!
attachment.php
Jhunt
