I would check all fluids make sure all is well and try to isolate that leak. Those heater valves can Crack abs snap.
Once the engine is ice cold. You can carefully open the radiator cap and check the antifreeze.
Do not touch a radiator cap if any heat is left to the engine at all.
The 3 red fluids would be antifreeze, Power steering along with transmission fluid.
Being those lines that are all coolant lines to the rear heater and the heater core. I suspect the leak in thst general area up top there.
Sent from my SM-A505U using Tapatalk
