If I replace (at least) my front turn signal bulbs with LEDs (which run at lower voltage) will they hyper-flash? Has anyone replaced these and experienced this? I hope not! Don't want to replace flashers or install resistors if I don't have to...
I have LED lights now in my new bumper, and they did flash to fast at first. After a little internet searching I found if you just wire two resistors (one for each blinker) in between the power and ground wire it will fix it. Cheap and easy fix!
the only reason i went with a flasher unit instead of resistors is because i could always revert it back to stock if i wanted too. with resistors you would have to cut them out of your wiring harness
I was going to do LED for front and back turns too, but was afraid of having the issue you were talking about. So I ended up buying silverstar bulbs for the front and back and they were really bright compared to stock. and cheap too $20 for front turns and rear.
all the led bulbs ive had fit in the stock spots just fine changing the flasher to a led one is super easy i used a Trico EP 35 make sure it says led on it
