LED kits for 5th generation 4runner(Help needed)
3 to 5 days:) doing orders more frequently now! Also, check your paypal because the tracking info is posted there:)
Thanks, I guess because I'm in Canada it's taking a lot longer. It's been almost 2.5 weeks now. I see the tracking number in the transaction details. Which site do I go to, to check the tracking details?
Unrelated question - is there a very bright LED that I can use to replace my fogs rather than going HID? I've seen one on v-leds, but not sure what it looks like when installed and turned on. Would it be bright enough? http://www.v-leds.com/Exterior-LED-Bulbs/DRLFOG-LED/9006/5K-WHITE-28-LED-13W-DRLFOG-p8022473.html
Unrelated question - is there a very bright LED that I can use to replace my fogs rather than going HID? I've seen one on v-leds, but not sure what it looks like when installed and turned on. Would it be bright enough? 5K WHITE 28 LED 13W DRL/FOG LIGHT BULBS HB4 9006 | 1 PAIR
What is your goal with the led bulb in a fog/headlight housing? Less draw? I think you would be better off doing an hid bulb because those are also less draw than oem halogen and time proven for the headlight and fog type application, definitely effective too. I cannot comment on led in the headlight or fog light but I am almost certain that it will be brighter than stock
My goal is simple. :) Purely cosmetic - get rid of the ugly yellow incandescent look. I have no use for the light output, so if I can replace the bulbs with LED's that change the color to a bright white as long it does not create glare for oncoming drivers. (definitely don't think it's worth substituting fogs to HID's - been there, done that on my GS400 and won't do it again as its a waste of money IMHO).
Let me check what price I can get you on the bulb! You want what type again?
Installation
OK, I know my pictures suck and I will try and retake some more tomorrow in the daylight.
I only covered the door/puddle lights and the hatch lights. The biggest pain was the overhead console light. I had a heckuva time getting those bulbs out, but the electrical tape suggestion worked with some wrangling. Here goes on the puddles:
KEY TO ALL MODS: TAKE IT SLOW AND BE CALM.
First get a small screwdriver and gently pry at the lense of the puddle light. I found the top and toward the engine compartment to be the first spot that would come out. Once the lens pops out, press the little release and separate the lens from the wire.
[url=http://jwbmgallery.smugmug.com/Cars/Dad/Reata-Toyota-4-Runner/19817753_Qvrwnp#!i=1670982308&k=zLGxThF&lb=1&s=A][/URL]
Here is another shot of it from the hidden side:
[url=http://jwbmgallery.smugmug.com/Cars/Dad/Reata-Toyota-4-Runner/19817753_Qvrwnp#!i=1670982911&k=2cvgcdm&lb=1&s=A][/URL]
On the hidden side there is a deep crevace that you can get your finger down into and it is springy. Press gently and pull outward to release the bulb cover. At the tip of my finger in this photo is the springy thing.
[url=http://jwbmgallery.smugmug.com/Cars/Dad/Reata-Toyota-4-Runner/19817753_Qvrwnp#!i=1670983345&k=tr8fkfv&lb=1&s=A][/URL]
Once you have released the catch by pressing on the springy thing, GENTLY pull straight up and wiggle a little to remove the entire cover. It will come off completely like this:
[url=http://jwbmgallery.smugmug.com/Cars/Dad/Reata-Toyota-4-Runner/19817753_Qvrwnp#!i=1670983845&k=cq2JLz7&lb=1&s=A][/URL]
Cont'd.
Next, take you screwdriver and gently slide the OEM bulb from the socket. Next insert the LED bulb. three of mine were the same polarization where the writing was inserted down. One was reversed and was up. Before you re-assemble, the lens completely, I would suggest reconnecting it to the wire to be sure the polarity is correct. If it is they will light up, if not they wont, to correct a non-lighting bulb jut pull it back out and flip it over. Once functionality is confirmed, gently place the cover straight down to enclose the lens. It should click on both ends and then be ready to install back in the truck.
[url=http://jwbmgallery.smugmug.com/Cars/Dad/Reata-Toyota-4-Runner/19817753_Qvrwnp#!i=1670984355&k=Sj8jJ8P&lb=1&s=A][/URL]
The hatch lights are easy too. From the drivers side is where you want to insert the small screwdriver as you sit on the bumper and pull the hatch down towards you. The tolerances are tight so it doesnt take much of the screwdriver to get in there to pry it up. Once it pry's out the side you are prying on will pop out readily. It has a metal spring that holds it in the panel as seen here:
[url=http://jwbmgallery.smugmug.com/Cars/Dad/Reata-Toyota-4-Runner/19817753_Qvrwnp#!i=1670985567&k=8r8SDNj&lb=1&s=A][/URL]
Unplug it and it will look like this after you seperate the actual lens from the housing itself. Be particularly cautious when removing the lens from the housing as those little pieces holding the lens on don't seem too stout:
[url=http://jwbmgallery.smugmug.com/Cars/Dad/Reata-Toyota-4-Runner/19817753_Qvrwnp#!i=1670985951&k=77KRzKw&lb=1&s=A][/URL]
Contd
The 3x3 that goes into the hatch have three different types of connectors. A screw in thing, a plug in thing like is used in the doors, and a spring loaded thing like is used in the center overhead light. You will want to select the spring loaded one as what you will need for the hatch application. Be sure that when you plug the spring loaded connector in that you match the colors on the wires. Pink with pink and white with white (P.S. I am color blind so just make sure they match). Mine came with the plug in thing attached. See:
[url=http://jwbmgallery.smugmug.com/Cars/Dad/Reata-Toyota-4-Runner/19817753_Qvrwnp#!i=1670986318&k=p93t7FP&lb=1&s=A][/URL]
Next squeeze the spring down so it will fit between the contacts. Once you are to this point, go back to the truck, and be sure they come on when plugged in (don't re-assemble completely. If they don't come on, just flip the spring loaded gadget over and then they will. Be sure the switch is in the on or door position or you might not know if they are on or not. After they are working, you will need to remove the 3M adhesive and attach the LED as so:
[url=http://jwbmgallery.smugmug.com/Cars/Dad/Reata-Toyota-4-Runner/19817753_Qvrwnp#!i=1670985565&k=sPD2cPk&lb=1&s=A][/URL]
Next, reassemble the housing and the lens and again be cautious of the clear plastic lips that hold the lens to the housing. I think these are probably the weakest part and would be the easiest to break (no, I didn't). Next go plug it back in and put the wire plug in first and pop it back in the panel.
You are done.
Sorry I didnt take any of the hard ones, but I wanted someone else to have some fun too. P.S. Sorry my pics suck so bad.
In an effort to make sure nobody gets mad again, I decided to work today since tomorrow is a holiday. All pm's and inquiries have been replied to and all orders placed Friday, Saturday and Sunday will ship out on Tuesday. In addition, replacement parts will also be distributed to those who inquired.
Another thing I need to address, I need to know the size of the 5th gen hatch lights, I think we can cram a 6x2 or even a 6x3 led panel in there. It will up the kit price but will amplify the improvement. Change in price shouldn't be more than $7-$9 this change is made.
Currently the hatch panel is a 3x3 led panel
OK you guys and gals, these lights are fantastic. You have to get these!! Get your order in now!!! You will love them.
So is this upgrade an easy install? I mean is it as simple as changing out a light bulb..LOL
Yes it is:)
Hope everyone had an amazing weekend! It is Monday and officially time to answer pm's since the work week is back!
Also, it is raining out there! Got mud?(or snow?)
Post pics here!
Have some free time! So I will send some requests out tonight
sent so far to:
limamike, RunninInGA, jangoforhire, ttudesperado
sending requests to people in the order that they were recieved via pm!
