LED Lighting Kits
Dane2992
Hi everyone. I'm on tacomaworld as tacodane, I now own a 4runner and I now offer led hood kits for 4runners.These kit will have everything you'll need, also all wires are wrapped in a braided black loom. No ugly wires showing. The LEDs are 5050 smd with a black PCB strip. No gaudy white strip. Every LED strip has an added acrylic adhesive tape that will hold up to any temps. All connections have heat shrinked ends to prevent water from corroding the connectors. Each kit will come with a switch, and add-a-fuse, zip tie adhesive mounts, and zipties, etc.
PRICING:
Hood kit for all 4runners w/ switch -$65
w/ both switches- $67
Rocker kit w/ 60" strips - $75
Also here is the link to my sale thread on TW- https://www.tacomaworld.com/index.php?threads/400988/
3rd & 4th geb install mixed in at post #92
5th gen install info on post #179
Here are a few photos of some of the Tacoma led kits I've made: uploadfromtaptalk1456242837484.jpguploadfromtaptalk1456242844699.jpguploadfromtaptalk1456242850167.jpg
Beta's gens:
1st-
2nd- Kyle11863
*DISCLAIMER* when payment is given through PayPal, I will use the address provided in with the payment unless stated in a PM. Also full payment will be requested if fees from PayPal are taken out. If you would like to send payment as goods and services, please add 2.9% in with payment
Photos
4runner photos!
Nice work. Interested for a 4th gen. Did this to my back hatch but haven't taken the time to build a proper one for the hood. Let me know if you need a "beta fitter" [emoji16]
Deff would like a beta fitter for other gens. Kits are discounted if they are beta's as well
I bought a kit from Dane about a year ago over on TW. His under hood LED light kit was great. Everything was of quality parts...the only thing I replaced was the switch I used inside. His switch would have worked...I just wanted one that matched my others.
I know he only has a few post here...but he's been around for several years over on TW! Just wanted to give everyone a warm fuzzy about buying from him.
Cheers
- Russel
Cheers
- Russel
Really appreciate the kind words. Glad the kits is holding up great.
Im up for under the hood and the one on the sides for my sliders!
Great! I was going to offer the rocker kits if anyone was willing to dive in. Idk if you plan to tap the dome Aire or not or to run them off a switch?
Interested for 5th gen
Great!
Great!
Yeah there is a slight problem with the rocker kit, my rear tailgate is kind screwed up it closes and locks but it always says its open so i have to turn the dome light off in the trunk area ( or it stays on the whole time)
BUT the front dome light works as it should, tunrning off and on when the doors are open or closed. Now im not an electrical expert or anything but where would this hook up to? it would be great if i can relay it to the front dome light. I wouldnt want to use the switch method, kind of defeats the purpose of it
From previous installs on tacomas, you would put an add a fuse in with your dome light fuse and then tap the dome dimmer ground wire.
freddygino
