LED lights: Turn Signals and Corners
i made my own corner led's for like 15 dollars
IMG_1431.jpg~original
IMG_1435.jpg~original
I purchased a set of LEDS from V-LEDS for my clear corners but was disappointed because it looks tacky when my HID lights are on and the aren't matched
I'd be more interested in a bulb I could utilize in the tail lights to match the LED brake lights. I'm lazy and I hate to search :sleepy:
Well what would kind of bulb do you guys think should go in my clear corners?
I'm waiting to get my 8000k hid kit right now, and I'm sure I will not be able to make the clear corner lights match up very well with the headlights.
mistaj0hnny, it looks like your clear corners are turned off completely with the headlights on. Did you just give up on the clear corner bulb idea?
I wanted to put some kind of bulb in the clear corners but have no idea what I should put in there.
I need some more suggestions on what to do... What have other people done?
Just trying to help make the mod go smoothly....
What are you going to do about the blinker? The reduced load of the LED will cause it to flash really fast as if a bulb was burned out. In general you can add resistors or change the flashers (turn signal and 4-way). More here: Blinker/Warning Fix
Edit: Looks like SilverBullet01 and I were typing at the same time:D
v-leds doesnt carry an iso flasher unit, they have a jso, but it needs to be rewired like i did in the previous post
edit: indeed sir :D
edit: indeed sir :D
:vader: Awesome... I know about this issue due to non-3rd gen experience. I just didn't want Rob to get the new lights and have not work.
I just read those posts. The flasher with jump wires look easy enough. Great info. Thanks:bigok:
Poor Zandro! The roof collapsing on that sweet diesel Runner.:cry:
Alright well it is looking like I should go amber then for the corners. And the LED blinkers sound like a small project.... Thanks so much for all your help guys
Hey, so im new to the site..I have a 02. Where can I find some clear corners.. The sites I've seen don't have the right ones...Any suggestions?
