leveling '05 runner w./ Xreas
Cable Guy said:
Any suggestions?
1" or 1.25" spacer lift. If you've read about spacer lifts you've undoubtedly run into the pre-load vs top spacer talk. In the 1" range it probably doesn't matter at all. The division of spacer becomes an issue when lifting more than you're talking about. Toytec, Cornfed and others make an appropriate lift for your needs.
:cheers:
leveling
All the spacers I've found so far have excluded application for 4 runners with Xreas. Any specific make and model for the spacers? thanks.
Of all the leveling kit threads I have read, no one has ever mentioned TRUXX leveling kit, is there a reason for this? The reason I ask, it is the one I plan on using for my wifes 4runner.
Re: leveling / lift & warranty
Cable Guy said:
Would this mod void my warranty?
They'd have to prove the mod caused or contributed to the failure, by law. A big lift will surely raise eyebrows and you might have to "fight" for the repair. A simple level will be fine.
:cheers:
I don't know... Be sure to let us know how it goes.
:cheers:
Re: leveling and warranty
Cable Guy said:
That's what I figured. It's pretty inconspicuous, they probably wouldn't even notice.
They would notice
You should be fine though
