Leveling Rake After Lift
ArmArak
Hi guys I just lifted my 2001 4Runner. I ended up with more of a rake than I was expecting (around 3 inches). I want to put a 2 inch leveling kit on the front to even it out a little. Which ones would you recommend? From what I have seen the spacers have bolts that are 60 degrees off the original on the shock's top hat, this means the shock would have to be mounted 180 degrees rotated for the spacer's bolts to line up. Doesn't the shock have to mounted in a specific orientation? How does this work?
wayblom
