1MZ-V8 said:Yes the bottom reflector piece on the LS430 and the housing ring on the headlight require some trimming. Just got the FX done so LS should be next on the list.
I was wondering if you can take some pictures of the headlight on the back (the part where you connects the wiring and stuff) I just want to see how much trimming was done on your retrofit.
lawwailok said:if you are saying the very back of the housing, surprisingly NO trimming were done! all my retrofitter did was trim the bracket that hold the stock projectors a little bit to fit in the bigger TSX, that's about all the trimming. and the D2S sockets are almost perfectly line up with stock bulbs positions too. so the back basically looks stock except the D2S plugs were stuck out slightly bit. you know what, i am already jealous on you LS430 bro., can't wait to see the pictures when yours finished. i am already prepared to yank out my TSXs if LS retro can do a perfect job but retain the stock look, that's what i am worry about trimming the stock bezel and don't want to ruin the stock shroud since they look very good!
1MZ-V8 said:Yes make sure you have an extra set of headlight in case it gets mess up! j/k ;p
blindside said:The capsules are glass.. i had used a similar one back when i was in the philippines.. we call those condomsI wanted to get one so bad but i couldn't find it anywhere... i saw one website that has it but they would not sell it individual.. i think they do retrofit
