Jester4kicks
Hey all, the UPS guy brought my OME lift today, and my light racing UCA's yesterday. I've been reading up on the install procedure, and I think I've mostly got it, but there are a few parts I'm still nervous about.
Here's the guide I'm basing the spring install off of:
OME Lift
In that thread though, the front springs/struts were assembled from the seller. Mine are not. As I understand it, this shouldn't be too hard. I plan on renting a spring compressor from advance auto, and it looks like you just get the two pieces on either side of the spring and start tightening them down until you can wiggle the spring freely. Is it harder than that?
I am also a little confused about the struts/shocks I received. There is a long metal clip that appears to be holding them in a compressed state. I'm not entirely sure how I'm supposed to get that clip off without having the thing burst to full length.
The only other thing that I'm concerned about is the UCA install.
I was looking at this guide:
Upper Control Arms replacement
As I understand it, the two toughest parts of the UCA install are disconnecting the ball joint, and removing the long bolt that holds the entire UCA on. Since I'm already going to be borrowing a spring compressor from advance, I figured I'd also borrow a ball join separator. As for the long bolt, I've heard I may have to pull that out through the engine compartment. Thoughts?
So far, here's my shopping/borrow list. Let me know if I'm missing anything.
-PB Blaster
-Spring compressor
-Ball Joint separator
-Strap wrench
Sorry for the length, all thoughts or pointers are welcome! Thanks!
OME Lift
-PB Blaster
-Spring compressor
-Strap wrench
