Lift for 35's?
BadBowtie
Hello, I recnetly purchased a '94 4runner, and I am ready to lift it. I would really liek to run 35x12.5 BFG Mud Terrains. I foudn a lift which is a combination of parts from OME, and SDORI, and it comes with: 2- OME901-Heavy load rear coil springs, 2- OME N72F- NitroCharger Shocks, 2- OME N98 -NitroCharger Shocks,1- OMESD33 SteerStabilizer, 2- SDORI Coil spring spacers, 2- SDORI Ball Joint spacers. It staes that it will ahve a 3-4 inch. Does this kit also lift the front 3-4 inches? I want to run this lift in conjunction with a 3 inch body lift. will I be able to clear 35's?
Thanks,
Danny
As far as I can tell, it will. If it comes with ball joint spacers, then it is a lift for the front as well as the back. I am a first gen guy, but I would say yes for clearing the tires. You could need to knock down a weld on the front, but you will most likley clear them.
You'll probably be OK, but expect some rubbing in the front at full turn and when the tire's stuffed (compression). Hammer flat the sheet metal seam in the rear if the front wheel well for starters.
