Lift installed - my review, pics, lessons learned...
audiness
Senior Member
Took some time over the long weekend to install the lift I bought from Toytec:
Front: TRD Tundra Coils, Bilstein 5100 adj. shocks (3 perch Tacoma version)
Rear: OME 906 Coils, Bilstein 5125 shocks
Before: Front-L 34.5 Front-R 34.5
Before: Rear-L 34.25 Rear-R 34.5
After: Front-L 37.5 Front-R 37.5
After: Rear-L 37.5 R Rear-36.5
Gained almost a full 3" over my extremely worn-out saggy stock suspension. After a few days I have noticed some settling in the front, the measurement is down about .5 inch on each side over the initial measurement. My stock shocks were hopelessly worn out, once they were off the truck, I compressed them by hand and they took about 5 minutes to return to full extension by themselves.
The ride: Immediately noticed a much stiffer ride overall, but I would describe the truck as very controllable, I had a lot of bouncing before the upgrade. I do feel a bit more body roll, but nothing too concerning.
Front- very plush, the increased suspension travel is very noticeable. I was a bit worried about using the Tacoma 5100s over the Tundra 5100s, but they feel great to me. It feels "lifted" but on-road handling is hardly affected. I need an alignment very badly now.
Rear - I was a bit worried about the 906s being too firm, but I think they feel really nice with the Bilstein 5125s. I did get a chance to go off-road just a bit, and the ride is much stiffer, but not jarring. I think the Bilsteins do a fantastic job of keeping things smooth.
The install:
Front- I was surprised at the amount of time/difficultly. The hardest part by far was getting the newly built coil-overs back into the stock location. I used a jack to push down on the front upper control arm as far as possible, I think I had it at "full droop." The upper ball joint looked like it was going to explode. I managed to get the bottom shock bolt back in after much tugging, levering, and hammering. I have no idea how people have done this with top plate spacers. If these shocks were 1mm longer i don't think I would have been able to get them back in the truck. I put the adjustable perch on the lowest setting, I am not sure if this makes it longer or shorter. I did install the front diff drop, hopefully i installed that correctly. It made me feel a bit more comfortable with the CV angles.
Rear - quite easy by comparison, I used the bend-the-original-shock-back-and-forth-until-the-top-nut-breaks-off method to remove the old stock shocks, and it worked well. Installing the new 5125s was straightforward, and the springs went in without much hassle. I did not install the extended brake line.
Before:
before.jpg~original
After:
after.jpg~original
Installed after much fuss:
front_coil.jpg~original
I ground down this point on the suspension arm just a little bit, as it was very close to contacting the spring:
grind_a_bit.jpg~original
hopefully i got this on correctly:
diff_drop.jpg~original
I concur - getting the 5100's in there was not a pleasant experience. Felt like I played in an NFL game the next day.
Great review on your Tacoma setup! I think this is one of the best options for those looking for a lower-ish lift and not breaking the bank.
Maybe practice makes perfect but I can swap out my front struts in 15 min per side now! haha Bottle jack placement is key....
I'm really hopin ya didn't grind down the spring :bravo: good work, pretty nice lookin rig
Haha, no I didn't grind the spring, just the little sharp point on the suspension arm! It didn't quite contact the spring at all, but I thought it wouldn't be a bad idea to file it down a bit...
Was just razzin ya as you where pointing at the spring!
yea the point on the arm was like within 1mm of touching the spring at full droop, I was worried with weight applied that there could be contact, although I have not read anyone else that has had and issue with it.
Spring contact on the spindle has been an issue for some. The fix is rotating the spring so that the spindle fits between the coils. Looks like you did it right.
BTW which notch are you sitting on the front bilsteins?
My 5100s only have 3 adjustments since they are the Tacoma version, I put the clip on the perch at the lowest point (towards the bottom of the shock).
Looks good. I would imagine that the less than smooth downtown streets are a little more jarring than before.
I am going to say Church St. in the second pic given the Victoria fanlight over the entrance in the background with the less than stellar sidewalks. My 4runner is residing with my niece at the moment between Ashley and Rutledge while she matriculates at CofC.
that is what it took to get mine it too, i put the fronts in by myself, was a pain, but i did it, even with the 1.5" top spacers,
dont know what i am gonna do when i get the bilstein's
My lower ball joints went out after I did my install. Make sure that you check yours. I went with the Tacoma lower ball joints and Tacoma out tie rod ends when I did mine. You might want to consider that later on since your lifted and larger tires. Just a though there. Lift looks great.
When I installed my 4runner with the Toytec springs and taco 5100s I noticed the coil on one side was scraping the uca/balljoint. When I looked at the otherside I noticed the way the coil was set and where the coil sat in coralation to the uca/balljoint. I ended up compressing the strut that was scraping and rotated it slightly and it now clears the coil at full drop.
patnewton
