Lift Kit - TRD Pro by Westcott Designs
As much as I would have preferred the Eibach front kit, I couldnt wait until September and ordered the front Westcott kit. I am definitely impressed with the initial quality of materials compared to the cornfed kit which I had and took off last year. (And swapped in the Icon 13" coils)
One question as it arrived yesterday. There are two bolts with lock washers and nuts in a seperate bag... what are they for?
Hoping to install it this weekend.. seems pretty straight forward in the video and have done other suspension swaps myself.
I was strongly considering the Wescott kit but was going to have them install. I don't off road and I am so back and forth about even touching my stock 2018 it's ridiculous. It's a lot of money, wheels/tires and lift, to look cool when I don't look cool outside the truck. But....I do like the ability to be able to go where I may need to.
I know yours will be great with the Wescott.
How is the ride compared to stock?
I honestly didnt notice a difference... Thats where the Eibach one and a slightly stiffer spring may be a better option.
Honestly I am really enjoying the stock ride compared to the Dobinson suspension on my ‘14. I would like a lift, but I do not want to stiffen up the ride. It appears the spring rate is higher with Eibach, but waiting on Eibach to confirm in the thread.
Its only slightly stiffer.
I was really set on the Eibach springs, but then I started reading about how superior the ride quality of Kings due to a lower spring rate. I also found an article on accutune off road about 4R and Tacoma spring rates and they also recommend lower, especially if you don’t have a bumper/winch up front. The accutune article seems to imply increasing preload would be preferred, as long as the shock/spring can support the new range of travel. This has me favoring the westcott kit a bit more because I am quite pleased with the ride on the ‘21 front coils, a little stiffer compared to my ‘19.
Did the front today, took about 2.5 hours. Was about to do the rear but used the wrong torque wrench.
750 lbs of torque turned out to be too much for my coil spring insulator, part# 4830235050
So now I'm driving with a nice Alabama squat. Took less than an hour to put the rear back together, so if I didn't screwed up I would've been done in about 4 hours total.
No idea how to upload pictures from my phone, I've tried .
Need Advice!
Hey all,
I have a TRD PRO 2018 4runner
The wescott lift is appealing, but I’m worried about rear sag when fully loaded, and eventually I plan to add a rear bumper.
What do you guys think about adding the wescott front kit (1.5 inch lift) and instead of the wescott rear, add a heavier, taller coil.
What length coil should I aim for? (1.5 or 2in)? I wouldn’t mind a slight rake for the time being.
Thanks for the help!
For comparison here is mine with Eibach springs which are way easier to install IMO and with 285's.
Before:
After:
What year 4Runner is this?
Understanding Why WD's Spacer Lift Is Different
A spacer on top of the front spring retains the front suspension geometry too and allows same suspension travel as without, so I still don't see advantage of Westcott, more $$ and complex install seems to me.
Digging it up from the dead, but for anyone wondering going forward....bear with me, this will be difficult to explain without graphics to help. I'll link to my source material at the end. Hopefully that will pull it all together.
The way I understand it, the PRO Fox shocks have the same stroke as an extended travel shock (not long travel, which requires longer control arms). The Fox shocks leave some travel unused at full extension. The lower spacer on the WD kit extends the shock to the end of that travel at full extension. So now, you've added that distance in droop, while pushing up on the spring, adding part of the lift.
The upper spacer in the WD kit is a top hat spacer, which pushes down modestly on the entire coilover, which is what raises the vehicle. So now you have maximized your extension, and your LCA still hits the factory bump stop under full compression. The coils maintain almost all of their length, so they won't stack on top of each other under full compression. So you've also maintained the maximum available up-travel (still limited by the same factory bump stop). Overall travel has increased to the maximum allowed by the UCA and LCA, and you're still close to the middle of the stroke at your higher static ride height.
Top hat spacer lifts just push the coilover down lower in the stroke (truck goes up). This means you lose travel on the droop side, unless you go to a UCA with added inside clearance so it doesn't contacts the spring, and with a higher angle ball/heim joint. They're trying to get some of that droop travel back. It also means a more extreme CV angle, which explains the 'need' for a diff drop to prevent premature failure of that connection,
Pushing everything down in the travel also means that on compression, either your coils will stack up on top of each other before the LCA hits the factory bump stop, or the spring rate will increase enough that the truck can't compress enough for the UCA to contact the factory bump stop under stock vehicle weight.
In both cases, you've lost up-travel because your LCA isn't making it all the way to the factory bump stop. Because the coilover is now taking so much force at the end of that travel, and the bump stop isn't taking that load, it can bend or snap off the bottom of the shock. This is why top hat spacer lifts often require longer bump stops...but again, you're stopping the up-travel before it swings thru the full available stroke. So you've lost droop and up-travel, meaning you've lost overall travel, and your suspension crashes into itself or the longer bump stop earlier, making the ride feel harsh. Not really a problem at Costco, but when off-road, your suspension is now much worse than stock.
Yes, WD is technically a 'spacer lift', but it's a well engineered spacer lift that opens up the full available travel, and maintains the ride quality of the factory PRO suspension, while still lifting it. The cheap spacer lifts reduce travel and compromise ride quality to achieve lift.
Unfortunately, I don't feel like Jeff does a very good job of describing these technical benefits of the WD spacer lift, but he's certainly come up with the best lift possible that utilizes and retains factory suspension components. The only way to get more travel without compromising ride quality is to go to long travel.
Here are the videos that helped me understand what the WD lift is doing:
Toyota IFS Construction and Limits
https://www.youtube.com/watch?v=_68Hc8GtLko&feature=youtu.be
Common Myths About Toyota IFS Lifts
https://www.youtube.com/watch?v=l1tTelhdEiM&feature=youtu.be
Extended Travel Coilovers for Toyotas
https://www.youtube.com/watch?v=ATmyTbMJL3o&feature=youtu.be
UCAs Functions and Misconceptions
https://www.youtube.com/watch?v=huMztKaHsUE&feature=youtu.be
Once you have that theory and knowledge in mind, apply it to understand what Jeff is saying in the final video.
WD Lift Description
https://www.youtube.com/watch?v=-RHFcE4OTsI&feature=youtu.be
Cheers! :usa2:
Yes, a complex subject! Tinkerer does a good job with his videos and explains things very well. He caused me to remove my 1" top hat spacer and replace with 1/2". And yes, Jeff does a poor job explaining his Westcott product.
Philthyphilthy
