Lift options?
atipps
Going to be lifting soon! I'm torn, it's between the toytec coil overs or the saw 2.0s. Witch do you guys recommend?
Subscribed! I'm getting ready to completely work over my suspension. I'm thinking about the Toytec Ultimate right now. I've been doing a lot of research and have heard nothing but good things. Adding the Sonoran Steel panhard bar has been recommended by several different forum posts from here as well as yotatech.com. Doing new LBJ's, CV boots, inner/outer tie rod shafts, other miscellaneous bushings, and sway bar links all at the same time.
I love my lift! Very good DD and off road. Front: Toytec adjustable coilovers. Rear: Sonoran Steel 1.2 rear only kit.
Do some searches on here and read the lift sticky. There are a lot threads on suspension lifts.
Its hard because they are both in the 700 range. Im looking for more of a comparison. Anybody with the saw 2.0s to testify?
Most of us use the toytec coilovers. Haven't seen much saw 2.0. But they are good quality.
