lift problems, xreas system
The same thing happened to my non xreas equipped 4runner after the lift was installed. It turned out one of the wheel sensor wires was snapped during the install. The wire was not unplugged prior to unweighting the axle. :(
HTH
If you still have no luck PM Bulldog. He's had lots of experience with suspension on the 4th Gen and should be able to problem solve with ya.
you have a bad ABS sensor line. Take it to the stealer and have them replace it under warranty.
The reason for the christmas tree lights is because the ABS sensor line got pinched (sensitive item) during the installation of the lift. It's a common problem when you are not careful since this item is very fragile.
The stealer should be able to fix it but if they do not and make you pay for it, have the lift installer pony up the cost of repair. The only reason the stealer won't warranty it would be due to the newly added lift. It's an easy fix for the stealer btw so no worries.
GOod luck
ABS wire fix is in the works
With your advise I traced out the wheel sensor wires. There are plugs at each wheel. The front wheels also have plugs above them under the hood on the fender wells. The rear sensor wires attach to one plug above the rear end. I unpluged all wheel and secondary plugs. I used a ohm meter to check each wire for continuity, two wires per wheel. When I got to the left front success, no continuity on the white wire. I'll order a new wire from the "stealer"(I like that) and update later. Check out the picture the Cornfed lift looks great. Thanks again to all.
Re: ABS wire fix is in the works
Nice Runner, how much stiffer is the suspension and ride with the Cornfed installed? I am curious to get that for mine, but the wife wants the cushy ride blah blah blah.
Re: Re: ABS wire fix is in the works
She probably won't be able to tell much different. It's rides very much like stock. Most report a "more stable" feeling after the lift is installed.
2001ATL
