onesojourner said:
I have been searching for a thread the discusses the advantages of each kind of lift and I have not found anything yet. can some one point me in the right direction?
What exactly are you looking to do with your truck?
Is it going to be a street queen or are you going to use it on trails.
And if you your going to take it on trials how hard core of trails are you planning to run?
If your just going to be a street queen, A bl is your best lift.
You look a little higher and you can get a larger tire underneath.
If you are looking to just do some minor wheeling and again don't feel like spending the money, a spacer lift will be another alternative, and again you can get a larger tire underneath.
A full suspension lift where you change out springs and shocks gives you a different ride and again lifts you higher.
Again larger tires.
but also there are different suspension options such as long travel. which gives you more articulation and a plusher ride.
those are just a few options, its really more a matter of searching to what you will be doing.
I searched for a lift that was best for heavy duty off-road use.
I try to hit the trails as much as possible.
so.
I needed something durable that would go a long way for me.
