Will I have to replace my shocks and shruts also? If I get a lift?
shocks yes, struts? what struts?
with a lift you only replace shocks and coils and then add diff drop (optional but recommend) you don't really need anything else besides those 2 maybe 3 things..
also a thing to mention is you don't need new shocks if your only going with a mild lift, and when i say mild it's like 1 inch or something like that. i am unsure of the exact number, but it's hardly worth mentioning, i would just figure shocks in to the overall price.
also keep in mind there's 2 types of lifts, a body lift (BL) or a suspension/coil lift, if you just going for looks a BL may be just fine for you. BL's are cheaper and easier to install (imo) and will give you that look your after, the suspension lift on the other hand it alot more money, but also has a lot more built in performance, and you get what you pay for, other's may disagree but i have ran nothing but a bl on some of my rides and noticed a crappier ride quality,not saying that's inherent with BL's but just my experience with them,
from my own personal experience i find the ride quality far better with a full coil lift.
so in summary
BL for looks
coil lift for performance/off road prowess
it should also be noted that both can be used in conjunction with one an another, it's not uncommon to have a coil lift with some bl spacers in there for the extra clearance on the larger tires.
what are you trying to accomplish here? just want bigger tires and spend 98% of the time on road, go with a cheap $200 bl and call it a day.
