Expat said:
I have read that one or two people have had rubbing issues requiring trimming the triangles, but I believe thgis is related to alignment settings.
Expat is correct about the alignment setting. If you set the alignment correctly, it won't rub at all, in most cases.
I have 285/70/17s and the only problem I had was a little rubbing on the inside corner of the mud flap. I just removed it and it actually looks better, I think.
Then again even though the tire sizes are the same, each manufacturer differ a bit.
The Revos will rub a little less due to its concave profile at the shoulder. The T/A KOs and the Terragraplers have a wider profile at the shoulders for being ATs. If you get MTs, you need a lot more room to clear the shoulder treads.
Bottom line... Just get the tire and the size you want and start trimming away. It's only hard the first cut... after that, it's FUN!
btw, I suggest you get the alignment done after the lift AND tires. If you get the alignment first and get the big tire later... then you might have to get the alignment done again to clear the bigger tire. Or do what I did, and get a lifetime alignment at Firestone or something. Make friends with the manager
Hope this helps.
