for those with the LR UCA.. i'm getting ready to install them as my alignment is whacked out after the lift springs and shocks went in
https://docs.google.com/viewer?url=http://www.spcalignment.net/instructions/25480-INS_WEB.pdf
based on the above install chart.. what position did you set the UCA when you put it in before taking it to the alignment?
lets use the letters A-G based on the chart
I read that adjusting caster on the TOP of the spindle actually pushes the wheel back closer to the rear of fender and causes rub on the body mount..
adjusting caster on the BOTTOM of the spindle pushes wheel forward away from body mount and closer to the front fender liner
since the UCA adjusts caster on top.. my understanding is that use as little as possible in combination with the lower cambolts to achieve desired caster so the wheel does not get pushed back to the point of body mount rub..
if my lower cambolts are maxed out (all 4).. what should i set the UCA to initially? i currently have -0.5 caster and +0.9 camber
thanks for any help
thanks for any help
