<Lights installed on LIMITED front grill?
Grug556
Anybody installed spots or other types of lights in the limiteds upper or lower front grill? If so what did you use to fix it to the truck? Did you have to build custom brackets? Any decent mounting solutions out there? THanks for any ideas on this one, ive searched for abit and havent found much applicable. These are full size lights, not light bards nor the small rectangle running lights some put in grills
Many thanks for any help!
:love:
Only thing I've done are raptor lights in the lower grill area, which just use a plastic piece on the back that screws into the rear of each light to clamp them in place...if you're looking to install pods or similar, you might have to make your own metal bracket that works similarly.
Thanks for this. You wouldnt happen to have any pics I could see would you? Thanks!! :love:
I'm hoping to finish a stealth install of the new LASFIT 22" amber lightbar behind the top grill of a 2020 ORP with a pro gill conversion. The unit arrived without the harness, two shippers. My initial review is posted on the LASFIT sight, Performance pics from behind the wheel will hopfully be dropping in a couple of days
:love:
Rago Fabrications offers a rather nice set of brackets and a cross-member specifically designed for a 4Runner.
Brackets:
4Runner | Behind the Grill Light | 5th Gen - Rago Fabrication
Cross Member:
Mounting Plate for Universal Hidden Bumper Brackets | Rago Fabrication
I have all of the above installed in my 2021 SR5 Premium, which has a slightly different bumper cover. That said, the brackets - specifically where the cross-member mounts - are adjustable. I would think there is enough adjustability in there to somehow fit a Limited. Here's what mine looks like with the front bumper cover off and on:
You mentioned that you had "full sized lights." Prior to the Diode Dynamics SS5 LED lights, I had a set of Cibie Oscar halogen lights on the same brackets:
Brackets:
Cross Member:
thanks for the pics. Wasnt sure when i saw the rago if it would fit a limited. Maybe some grinder work will do it
