Likely annoying boneheaded lift question
Moto13
I promise I searched and read.
I've got a crazy lean I posted about before. I had an issue with the driver rear trail arm mount at the frame. New saf t cap welded in and everything is square and perfect. The lean however persists. On a previous post some suggested that my rear suspension was in rough shape. No bump stops, etc.
Sooooo, I'm looking at my options. Right now I have 2" tall springs. I have brand new 275/75/16 MTs. The front sits perfect and has lots of new components and a good alignment. It's the rear that's bottoming out on the trail and rubbing when stressed.
The Toytec 3" is $900. It's nice but in the last two months I've done a new ARB bumper, winch, and new set of tires. Will it be a problem if put something like OME 890s and Bilsteins back there? The rear will likely be a little higher and will have a different spring rate than the front. I did build a shelf system and keep a bunch of tools and equipment back there.
TLDR: rear suspension is borked and I'm trying to be cheap.
Sent from my SM-N950U using Tapatalk
have you taken a good look under there to see if the springs are seated correctly and that you’re not missing parts?
I just put some 890s on my rig and went from 19.75” to 22.5” hub to fender in the back. already had bilstein 5100s
edit: the 890s are slightly taller on the drivers side, you could also put a 10mm spacer on top.
youngrk
