1999 Tall OEM suspension replacement with OME spring and Bilstein shocks suggestion
NoVA_T4R
Member
Hello,
Back at 170k miles, I replaced my front suspension with OEM 1999 suspension parts. 99 tall springs, shocks and all the related OEM bushings and wear and tear parts.
Afterwards, I replaced the rear suspension with OME, Bilstein, and OEM bushing-like corresponding parts to match 99 tall in the front. I've lost the part numbers for the back in a hard drive failure.
I'm now at 339k miles. The front suspension is getting jumpy in terms of the shocks. The springs seem OK, so maybe I can hold off on the springs in the short term.
I need to replace the front suspension parts, want to do OEM bushings and etc, but want to do OME springs and Bilstein shocks to match the OME and Bilstein rears. I replaced the steering wheel rack bushing with a Wheeler's poly bushing (what's the lifespan for that part, BTW?)
If you can point me to any posts that list out the exact PN for OME and Bilstein for front and rear of T4R 1999 suspension, I'd really appreciate it.
I can't seem to find them and I've got home repair things that just popped up (water line leaks, plumbing, septic tank) so I'm burning the candle at both ends.
Thanks in advance.
Use your current springs in the front. You can look up Bilstein PNs very easily yourself on their website.
The bushings and other parts should be pretty good still... but you can refresh them is you want, I suppose.
-Charlie
Hello,
Thanks in advance.
2X Shock bushing 90389-14048
2X Front shock cushion 90948-01056
4x 90948-A2004 retainer
2x 90948-02119 retainer
2x 90948-03011 washer
