Limited leveling kit help please.
voodoolord
Bought a Toytec leveling kit for the 2015 limited and I can't seem to get the strut loose because of the Xreas hose attached. Is it ok to unbolt the hose and if so can you bleed the system or is there a way to get it loose without messing with the hose? This is pissing me off.
May want to wait till someone more experienced replies, but there is a certain way you can disconnect the xreas to keep it intact. I believe you can loosen the banjo bolts wi Hour it leaking.
i would not disconnect the hose unless you want to kill the x-reas.
if you have spring compressors, you might be able to compress the coils enough safely release the nut on the shock stem to install the spacer. you will probably need to loosen the lc bolts to drop the lc for clearance.
fhgy0045
