SeattleMike
Link
You know that two weeks from now you'll be able to buy "key extenders" on the internet for $200. :keyboard:
Normally, when a wireless key is within a few meters of the right car, it detects a low-powered signal that causes it to issue a command that opens the car enable the ignition. The researchers used a pair of antennas to transmit these signals from the car to the key when the key was farther away, tricking the car into opening without the ordinary authorization. One antenna needs to be very close to the car, and one needs to be within eight meters of the key.
The researchers came up with two versions of the attack. In one, they ran a cable from near the car to near the key and used it to transmit the signals. They conducted the other wirelessly. Francillon says that the materials for the wired attack cost about $50, and those for the wireless attack cost between $100 and $1,000, depending on the electronic components used.
The researchers tested a few scenarios. An attacker could watch a parking lot and have an accomplice watch as car owners as entered a nearby store. The accomplice would only need to be within eight meters of the targeted owner's key fob, making it easy to avoid arousing suspicion. In another scenario, a car owner might leave a car key on a table near a window. An antenna placed outside the house was able to communicate with the key, allowing the researchers then to start the car parked out front and drive away.
