My brother has worked hard all through highschool and purchased a 95 4wd w/120k miles cash at 17 years old. He's had the transmission, torque converter, entire braking system, etc. overhauled in the couple thousand miles he's had it. Not too much of a reward for working hard. He's about 4 grand into it service work including tires [doesn't include purchase price]. The truck has developed another possibly big problem. He needs to get this taken care of as cheaply as possible and cut his losses.
The wheel bearings in the front both have about 1/3-1/2" play up and down. The bigger problem is that the axle that goes into the right side of the front pumpkin has way too much play, probably 1/2" again, maybe even slightly more. It's causing a loud grinding noise when turning, even when it isn't technically engaged through the 4wd system. To be more specific, it's the passenger side axle/shaft.
I'm worried it is eating at the gears inside the casing, but I've never owned a SUV muchless a 4wd one. I am very mechanically inclined but this is unfamiliar territory for the most part.
The shop he took it to before I got a chance to evaluate it was quoting things like 1500-2400 depending on the condition of the insides of the casing. I went there and checked it on the lift as well as spoke to the mechanics, which is where I got the info. I posted above.
The truck does not have hubs supposedly, but what have you guys typically paid to have the wheel bearings done? Has anyone had this shaft 'fixed' and with what results/costs? Thanks,
Steve
Steve
