oldskoolvws
Finally installing a relatively easy alarm into my 87. I'm soldering all the connections and have a few more to go. I'm good with electronics and such, just looking for some experience to reduce my troubleshooting time.
I'm at the door lock / unlock portion and cannot find the lock relay which is supposed to be behind the drivers speaker. I have cruise control so I'm thinking the relay is moved. When I click the locks, it seems the relay is triggering from the passenger side, behind the ECU. I found the pink & white / brown & white wires behind the drivers speaker but they just remain in a harness. They are 12V constant.
Anyone experience this? Also, does the relay control both doors or only the passenger when you push the switch. Why do I have the feeling I'm going to have to wire the doors
Thanks.
Thanks.
