Location of ABS Relay on 2000 T4R - 5VZFE - 4x4
BamaDrewski
Trying to find the location of the ABS relay on my 2000 T4R Limited, 5VZFE and 4x4. If anyone can help (hopefully with photos) I would really appreciate it!
That's the ABS ECU, which might be what he really wants. However, the ABS relay is in the passenger kick panel. It has two white two-row plugs.
Per the wiring diagrams for the 2000, the ABS relay is in the engine compartment on the passenger side inner fender near the firewall. The ABS ECU is in the passenger kick panel. I've never needed to mess with either, so I can't promise the wiring diagrams are correct, but that is where the diagrams indicate they are.
That's what i also thought. the ABS ECU is about 3" x 3" and about an inch thick. It's behind the RH sidekick panel.
the ABS relay is the one beside the ABS Actuator and bolted to the inner fender and yes, with two plugs
