Looking for Cargo Cover in Moon Mist
Zhehan
Member
Hi All,
Anybody have a cargo cover in good condition for a 3rd Gen in Moon Mist that they don't use/want?
Lemme know. I'm in the Portland, OR area.
Cheers.
Sorry to barge in here, but I noticed your build has the TrakMotive EXTD axles. I have a pair that I'm waiting to install. Did you do the install yourself? If so, were there any issues/tips you can share or was it straightforward? These will be my first DIY axle job. Thanks!
I did the install myself. No issues. Paint the exposed axle and CV joint with chassis paint to combat surface rust. I would just get the Iron Armor chassis paint from Harbor Freight. It is chip resistant and seems durable to me. I used it on my sliders as well and it's holding up.
Also, I would watch a CV axle R&R video first if you haven't already: https://www.youtube.com/watch?v=5_xhXDU_Lts
Hope this helps!
Cheers
Hope this helps!
Cheers
Thanks, that does help. I have watched a bunch and always a Timmy video cued on deck for pretty much every big job I do.
Did you use new LBJ bolts?
I replaced everything that wiggled on that truck in 2022: Ball Joints, Axles, UCAs, LCA Bushings, LCA Cam Bolts, Inner and Outer Tie Rods, Rack Bushings and End Links in the front. Upper and Lower control arms and new Track Bar Bushings and end links in the rear. New rear axle bearings and seals as well. Plus an all new suspension eventually. It was all due. It's all just bolt on parts when you get down to it.
I upgraded stuff that I thought needed an upgrade since the truck is lifted. The stock parts are good for the stock vehicle when it comes to the arms and bushings related to that. The JBA UCAs in the front and the SPC lower links in the rear were huge, noticeable upgrades that I cant recommend enough. The Mevotech Supreme upper links were also a notable upgrade. It's amazing that there are now more choices for lifts and upgraded parts related to that for these trucks than when they were still available new from Toyota.
Cargo cover
Did you locate a cargo cover yet? Moon Mist, that is the light charcoal/gray color, correct?
Either way, I have one in both the gray, and the beige/tan. The tan one is from a 1999, and the gray one is from my current 2002. Let me know if you need any more information. Thanks.
