Ultimate Storage & Sleeping System for Toyota 4Runner (4th, 5th & 6th Gen)
WHEELSFEELS
official vendor
Hey 4Runner crew! ?
If you're tired of loose gear, clattering totes, and messy cargo setups on the trail, we at WheelsFeels engineered a heavy-duty solution. We’ve turned the 4Runner’s rear cargo area into a fully organized, noise-isolated mobile basecamp that bolts right into your vehicle’s factory holes - 100% bolt-in, zero drilling, cutting, or permanent mods required.
Here is a breakdown of why this setup is built for serious overlanding and daily utility:
Configurations: Choose between a 50/50 split, a 60/40 split (ideal for solo setups where you keep one rear seat up), or a single 100% full-width drawer for maximum open volume.
Height Options: Available in 5" (minimalist / low-profile), 7" (the optimal sweet spot), or 10" (maximum storage capacity).
Deep Cargo Space: Standard 33" inner depth gives you massive storage room for tools, recovery gear, and camp kitchen essentials.
Weight Rating: Heavy-duty drawer slides support up to 250 lbs fully extended. The top deck easily supports up to 400 lbs total (on split systems), so you can stack heavy totes or coolers right on top without flex.
100% Weatherproof: Built using marine-grade plywood with a waterproof varnish coating or heavy-duty carpet finish. It’s built to withstand rain, mud, and spilled camp gear without swelling or warping.
Rattle-Free: Acts as an additional layer of noise isolation from the trunk floor, staying 100% quiet and squeak-free even on rough, corrugated washboard trails.
? Full Compatibility Across All Generations
Whether you're running an older rig or a brand-new model, we engineered dedicated baseplates for exact OEM fitment:
4th Gen & 5th Gen (2-row standard, 2-row with OEM Rear Cargo Deck, 3rd-row seating, or 3rd-row removed)
New 6th Gen & Hybrid models (engineered specifically for raised cargo floors and battery setups)
?? Made in the USA | Lifetime Warranty
Feel free to drop any questions about fitment or specs below! ??
jesslstn854
