Looking for Help swapping out Headlights on a '99
Razorback
hey guys. tired searching for this and it's probably a dumb question but I have my replacement bulbs (GE Nighthawks) and am having trouble getting them swapped. The manuel is not helping me too much. I disconnected the wiring harness and removed the little foam cover that has the tab which says "top/pull". after that, the book says to disconeect the pin. Problem is is that I do not see a pin or anything and the bulb is not coming out because of a black rubber piece. can anyone help me or does anyone know of a piocture guide for the replacement. thanks
took her to the dealer for oil change today and had them take a look at helping me out and even the tech didn't know how to switch them out
should be a pin running across the back of the bulb base thats holding it into the hole opening to your head lights. What seems to be holding the bulb in?
that's part of my problem. I don't really know what's holding them in. the tech recomended taking a pair of pliers and trying the pull the bulb out by the prongs because it looks like the bulb is just stuck in there?
no dont do that, there should be a small, thin metal clip type thing that all you have to do is put pressure on it and unhook it. Ill see if i cant find a picture on here somewhere.
Replace Headlight Bulbs
One of the easiest (and most noticable) modifcations you can perform on your truck is replacing the factory headlights. A set of high-quality aftermarket headlights can not only improve the appearance of your truck, but can also improve your nighttime vision.
When shopping for aftermarket bulbs, it's important to make sure you purchase the correct bulbs. For all Tacoma models, you'll need to purchase size H4 bulbs.
Installing aftermarket bulbs (or replacing a blown factory bulb) is easy. Click the arrow below then follow the directions on the following pages. If you have questions or comments about this procedure, email CustomTacos.
IMPORTANT NOTE: When performing this procedure, it is VERY important NOT to touch any part of the glass lens on either the old or new bulbs. Oils from your fingers can rub off on the bulb and cause them to spontaneously blow when powered on.
It is helpful to go ahead and unpackage the new bulbs before you start. Since it is so important not to touch the glass lenses, I found it helpful to open the packaging of the new bulbs first.
Pop the hood and locate the back of the headlight assembly on either side. Since the battery is on the driver's side of the truck (thus making it harder to work with the rear of the headlight), I found it easiest to do the passenger side headlight first.
Remove the rubber cup weather seal from the wiring harness.
There is a small metal spring-loaded clip that holds the actual bulb in place. Unhook the clip the release the bulb. Be careful not to let the bulb fall out.
Install the replacement bulb. It has three tabs on it that will slide into the slots on the headlight assembly.
Replace the rubber cap on the headlight assembly. This is the trickiest part of the installation. Make sure that the wiring harness is securly on the bulb and that the rubber cap is completely on.
That's it. Turn on your headlights and make sure that both bulbs power on.
also here is the original LINK to the website where i found the article. Hope this helps!
also let me know if this isnt what your headlights look like.
