Looking for some LC 7 wraps!!
1bad4r
Anyone know where I can get some? I'm ready to buy but can't seem to locate any.. thanks for the help
I've bought 3 sets of 8 wraps of 8 wraps all from IH8mud.com. Just go to the part out section for the FJ80 model and pm everyone you can saying you want to by theirs. It shouldn't be too hard to find a set $60.
Thanks man I'm one step ahead of u that's what I'm trying already
I have the following:
1 x Double Pink Light Blue White
1 x Purple Green White
I bought the set from Man-A-Fre and they reportedly came off a '96 LC they did a lift on.
Asking $70 + Shipping. (exactly what I paid)
I am also looking for 7 wraps. Everyone has good info but it usually ends up being 8 or 9 wraps.
Got to remember guys if you get used 7 wraps they most likely sagged over time so 8's might work pretty good since they have settled. Im buying a set of new 7.5 wraps for around $200 shipped. Cost a little more but its nice to have new coils over used ones. I mean my used ones are already shot, why would I want more used coils.
Can anyone tell me if it's normal to have two different color codes on a set? I noticed there is 1/2 inch difference in these. I have heard that it's to compensate for the drivers side weight with the gas tank?? If someone can confirm this then I will buy these from you
Yes its normal, just use this as a map for the type you are looking at.
The FJ80 Landcruiser Spring
a cheap effective way to achieve a good amount of lift and flex is to install FRONT springs from a FJ80 (1991-1997) Landcruiser in the REAR of the 3rd gen. there are many different versions of these springs but that main way to identify them is to count how many wraps they have which generally will determine how much lift you will get. you can usually pick up a pair of these for under $100 at a junkyard or on a forum classified section.
7 wrap is about 3-3.5" of lift
8 is about 4"
9 is about 5"
Height of spring/color code/wraps
21" Blue Pink White 9.25 wraps
21" Grey Orange White 9.25 wraps
20.25" Blue Yellow White 8.75 wraps-one of these is a confirmed LX450
19.5" Green Yellow White 8.25 wraps-one of these is a confirmed LX450
19.5" Purple Green White 8 wraps
19.25" Double Purple Dark Blue White 8 wraps
19" Double Pink Light Blue White 7.5 wraps
18.5" Double Pink Grey White 7.5 wraps
18 7/8" Orange Orange White 7.75 wraps
