Loose heat shield sound
michaelreed
Alright guys I need some help. I have what sounds like a loose heat shield or bad cat. It sometimes happens if i rev during idle and usually only happens at low rpm or going up hill lightly accelerating. I've been under my runner like 5 times and can't isolate where the sound is coming from. No heat shields appear to be coming off and I banged on the cats and nothing rattles. Anyone else have issues like this that they have resolved? Any other ideas on what it might be?
It is the heat shield that is wrapped around you cat on the exhaust manifold itself. Both if mine do it, and there is no good solution, other than replacing the manifold and cat. You can take a punch and put a few dents in the heat shield near the seam to help tighten it up, but I will end up rattling again.
Are you talking about the cats closest to the engine or the after cats? It appears I have a pacesetter on the passenger side because I only have one cat with a heat shield and it doesn't seem loose.
Check the heat shields ABOVE the exhaust. I've have them get loose and rattle. The corroded around the bolts; I had to add larger washers & that solved my problem.
Checked all of them. None are loose or rusted off. The sound itself sounds more like the cat heat shield but its not loose. Could an exhaust leak cause this sort of noise? On occasion when I turn the 4runner on after its cooled off I hear a ticking sound. So Im pretty sure I have a leak somewhere but I'm not sure if that and the thin metal rattle at low rpm are related.
I've had the exact same issue the past 3 weeks. I hear it during idle with the windows down and when driving slow over a bump. I've gone under with a rubber mallet with the car in drive and parking brake engaged (I know,`stupid) and nothing seems to be coming from the heat shields. I can hear the rattle when underneath and think I can localize it past the cat, possibly the headpipe or muffler. When I'm driving the exhaust in general doesn't sound quite right either.
Keeping an eye on this thread.
...I should also mention I have a aftermarket Gibson exhaust.
I had a rattle like this at one point, the heat shield above the muffler had come completely off and was resting on top of the muffler and rattling. It was too big to come out on its own, but I finally just pulled it out and it went away
use some wire ties from home depot
and pad it with sticky foam - i had the sound and this stopped it
Hmm. Well ill keep you guys posted. Was kind of hoping someone had a similar sound that turned out to be something else that I haven't found. I may pull the cat heat shield off since there's a heat shield on the body too and see if that's it even though its not loose just to be sure.
Ok just turned it on and revved it and got underneath and I'm pretty sure I've isolated it to the drivers side cat. Not sure if its the manifold cat or the after cat though. Can a muffler shop weld in a new one or does it need to be direct fit?
I had this problem with both of my heatshields on my 03, after removing them both each time the sound went away. I'd be shocked if it was in fact your cat, but anything is possible. You don't have any indicator lights correct? When my cats went bad, my dash lit up like a Christmas tree
Few things make as much noise as a cheap inexpensive non critical component. If it sounds like a vibratory in a coffee can its just the heat shield
charlesz
