loose shifter
jiml100
1995 4runner, just got it and the automatic shifter has a lot of play, works fine just seems very loose, is there something to tighten on those. also any ideas on lifting rear end, someone turned torsions up front up then it all alighned so im going to leave it, back looks 2 inches lower now. thanks for any info.
Moog ccs255 rear springs ~$55 on amazon will bring it back to ~ stock height and with the t-bars mostly cranked on mine i felt 1.25" daystar spacer would bring it level i should have gone 2" but 1.25 is enough
As for the shifter i havent a clue
There are two little blue bushings in the shifter. They're available through the dealer. The original ones have most likely disintegrated. Take it all apart and plug in the new ones, it will be good as new.
